Pipe Insulation - How thick?
Henry Rosin
Member Posts: 1
My project is a 100 yr. old colonial renovation. All of the asbestos has been removed from exposed pipe on this one pipe steam heating system. Pipe insulation is the next project. What thickness of fiberglass pipe insulation is appropriate for the New York metro geographic area?
i use 1''
because the asbestos was 1''..but alot of guys use 2''.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
In NYC...
...the Code says 1".
That's usually good enough.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Insulation Thickness
You could probably go as low as 1/2" thick fiberglass. Just keep in mind what you are trying to accomplish. You want to keep the steam in a vapor form till it gets to the radiator. Not have it condense before it gets to the heat emitter. So the thicker the better but more $$$$$.
Darin
Now I understand . . .
why my contractor used 1" when some people had recommended up to 2"0 -
just causing trouble
Another perspective is to ask how long the insulation is going to last(say 50 years). Then divide by two and make a wild guess about how much energy is going to cost then (in 25 years). Insulate to that level :~) Think life cycle cost rather than first cost.
yours, Larry0
- 167 Indoor-Air Quality
