Please help quick!! (Expantion tanks)
Weezbo
Weezbo Member Posts: 6,231
standing on the floor hanging from a hook laying on the ground ... if it is there it will do its thing.one biggie though it does have to be piped into the system or its physical presence alone will not do the trick.:)
  • EE
    EE Member Posts: 2
    Expantion tanks
    Do expantion tanks need to be mounted lying only vertical or hanging down or can they bemounted with the inlet face down also?????????????
  • tom_49
    tom_49 Member Posts: 267
    any way.
  • bob_50
    bob_50 Member Posts: 306
    It's O.K.
  • Ken D.
    Ken D. Member Posts: 836
    exp. tanks
    I assume you mean a diaphragm type tank. If so, then any position will do as long as they are not used with an airscoop. If it has an airscoop, it will need to be hanging. Regardless, make sure they are supported properly.
  • If you're thinking...
    about screwing it onto the boiler someplace upside down, don't do it. It will fill with water and it WILL break the pipe, thereby breaching your vessel. And that ain't pretty.
    Always properly mount it in a safe and secure place.
    Did you know, it is illegal to hang an expansion tank from the bottom of an air seperator in New Mexico?
    The AHJ down there decided that because everyone and their brother was using Entran 2 hose, and the lack of o2 barrier caused the expansion tanks to rot due to oxygen, and the'd fall off and hit the floor and make a big CLUNK and scare people. So to avoid scaring people, AND maybe not having tanks rot off and hit the floor, they banned people from hanging the ex-tank off of the fitting for which it was inteded.
    They should have banned non O2 barrier tubing for use as a heating system component. The ex-tanks would still be there, and there'd be a LOT less insurance claims for water damage from tanks going CLUNK, SHHHHHHHHHHHHHHHHHHHH. and we wouldn't be having this conversation :-)
    Some pipples kidz, I'm tellin' ya...
    ME
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,712
    I just spit
    coffee on my screen.
    Retired and loving it.
