Taco ESP zone valves
JOHN_103
Member Posts: 54
joe i need a zone valve for a oil coal boiler, powered closed open on power loss. what #'s i need to order the right valve ? it's 1" swt?
what's the word on these new valves? endlessly frustrated with honeywells v8043's and hoping this is the answer. if anyone has any experience with these, your feedback is appreciated.0 -
I asked the local rep here and he says the ESP powerhead was changed a couple years ago, but that he doesn't know of anything newer than that.
Tell me about your problems with the Honeywell V8043s. Maybe I can help. And have you seen the new 5000 series with the snap-off powerhead and no-water hammer motor?0 -
hwzv
I've had some instances where I have replaced power heads or entire valves every year. The lubrication in the shaft looses effectiveness and the valve won't open far enough to close the end switch or the valve won't close all the way causing an over heat situation. A lot of techs that I've talked with have had the same experiences with the v8043 assemblies.
Not familiar with the 5000 series.0 -
The Taco ESP zonevalve is fully compatible with all thermostats, with a dual capacitor system to improve response time and torque rate. The first generation ESP had a NO/NC switch on the side but this caused a lot of confusion in the field, so Taco eliminated the switch but still offers the valve as normally closed (standard), and the normally open version. The ESP continues to be the smartest valve in the world. The features it offers compared to the competition makes it the zone valve choice for contractors.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
joemat@taco-hvac.com
Craig
I've used them a few times and I really like them. As Joe said, the first generation could be run NO/NC with the flip of a switch. I miss that option.
I was forewarned by my supplier (in 2002) that the motors were not always opening up on the first wave of ESP's. That was true, and they made good on them. No problems since.0 -
i have installed hundreds of them *~/:)
the first runs and the newer runs . bought about 60 of them a few months ago and i am already out of them:)
the i series with out door reset or set point control will match the valve body. this means that you can offer an up grade in certain instances when the funds become available :)or the reasoning becomes apparent *~/:)0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
