BACHARACH 60
Ted_9
Ted_9 Member Posts: 1,718
Pull the probe out when the co starts to climb out of range?
  • bill_67
    bill_67 Member Posts: 29
    BACHARACH 60 TESTER
    I HAVE A BACHARACH 60 TESTER, AND TRY TO BE CAREFULL DURING TESTING BUT STILL FIND I HAVE TO CHANGE FILTER WAY TO OFTEN AND AT WAY TOO MUCH EXPENSE,ANY CONSTRUCTIVE CRITICISM WELCOME.
  • targetman
    targetman Member Posts: 105
    I can't imagine why you are going through so many filters. You need to talk to Rudy Leatherman.
  • Dick Charland
    Dick Charland Member Posts: 178
    Bill, what are you testing with the unit, oil or gas? If oil, you need to do a smoke test first and adjust burner to 0-trace of smoke, then use analyzer to make final adjustments. Where are you located?
  • bill_67
    bacharach 60 tester filter
    first off thank you all i love this type off help, i am located in alaska,i am testing for smoke before and after and i am testing on oil burners, i am carefully adjusting the air in small increments but i still get a dirty filter sooner than i like,i hoped that there was a better or cheaper filter out there and i do pull the probe first sign off a rapidly climbing co.
  • Jim Davis_3
    Jim Davis_3 Member Posts: 578
    Buy some yarn and use it. That is what the original filters had in them.
  • bill_67
    BACHARACH 60
    THANK YOU JIM FOR THE TIP ON YARN THAT IS JUST WHAT I THINK I NEEDE TO SEE,AT THE RISK OF LOOKING IGNORANT I HAVE TO ASK WHO IS RUDY LEATHERMAN REFERED TO EARLIER.
    THANX FOR ANY TIPS EVERYONE
  • Rudy
    Rudy Member Posts: 482
    Hi Bill
    I work for Bacharach, give me a call when you have a chance. 412-576-1350.
    And, by the way Jim, it's not just any yarn, we keep specially genetically engineered sheep out back at the plant!!
  • Jim Davis
    Jim Davis Member Posts: 305
    Sheep!!
    I hear that is also one of the spiffs for the employees.
