BACHARACH 60
Ted_9
Member Posts: 1,718
Pull the probe out when the co starts to climb out of range?
BACHARACH 60 TESTER
I HAVE A BACHARACH 60 TESTER, AND TRY TO BE CAREFULL DURING TESTING BUT STILL FIND I HAVE TO CHANGE FILTER WAY TO OFTEN AND AT WAY TOO MUCH EXPENSE,ANY CONSTRUCTIVE CRITICISM WELCOME.0 -
I can't imagine why you are going through so many filters. You need to talk to Rudy Leatherman.0 -
Bill, what are you testing with the unit, oil or gas? If oil, you need to do a smoke test first and adjust burner to 0-trace of smoke, then use analyzer to make final adjustments. Where are you located?0 -
bacharach 60 tester filter
first off thank you all i love this type off help, i am located in alaska,i am testing for smoke before and after and i am testing on oil burners, i am carefully adjusting the air in small increments but i still get a dirty filter sooner than i like,i hoped that there was a better or cheaper filter out there and i do pull the probe first sign off a rapidly climbing co.0 -
Buy some yarn and use it. That is what the original filters had in them.0 -
BACHARACH 60
THANK YOU JIM FOR THE TIP ON YARN THAT IS JUST WHAT I THINK I NEEDE TO SEE,AT THE RISK OF LOOKING IGNORANT I HAVE TO ASK WHO IS RUDY LEATHERMAN REFERED TO EARLIER.
THANX FOR ANY TIPS EVERYONE0 -
Hi Bill
I work for Bacharach, give me a call when you have a chance. 412-576-1350.
And, by the way Jim, it's not just any yarn, we keep specially genetically engineered sheep out back at the plant!!0 -
Sheep!!
I hear that is also one of the spiffs for the employees.0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
