Decorative grill question (Dan H.)
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,643
about decorative grills such as <a href=" http://www.beaux-artes.com/products/arts_crafts_grilles.html"target="_blank">these</a>. Does anyone know of a source that might have better prices than that site? Thanks.
Retired and loving it.
  • Brad White_184
    Brad White_184 Member Posts: 135
    Those are not
    bad looking grilles and the prices are not that bad either, IMHO. Glad to have found them.
    Reggio comes to mind but the castings are flatter and with less detail. I am not sure you would find grilles as nice as these at those prices.
    My $0.02
    Brad
  • Tom_80
    Tom_80 Member Posts: 22
    Try this
    They do custom gilles and registers too.
    Barker Metalcraft
    2951-55 N. California
    Chicago, IL 60618
    1-800-397-0129
    Come see our new location.
    Got an idea? Fax us a sketch!
    Ofc: (773) 588-9300
    Fax: (773) 588-9309
    barker@radiatorcover.com
    Custom Radiator Covers
    Custom Radiator Covers by Barker Metalcraft will:
    Beautify your home
    Protect your drapes, fabrics and walls
    Best quality
    Reliability
    Heat efficiency
    Why should you contact Barker for your radiator cover and grille needs?
    Barker Metalcraft has been manufacturing quality custom radiator covers and grille covers for over 30 years. We use only the best materials to make our quality products. For example, for our radiator covers and radiator enclosures we use 16 gauge steel for the tops, and 20-gauge for the main body. And we incorporate reflective backs to maximize the heat flow from your radiator enclosures. It costs us more money to do things this way, but it saves you money in the long run in heat efficiency (and you know how high heating costs have been the past few years!)
    You will also be happier with the final product, which will beautify your home, and last a long time, unlike cheaper radiator covers that easily dent, sound "tinny" and look bad after a year-or-so of use.
    If you have an unsightly radiator or vent, we can design a cover that will blend in with the d
  • Glen_7
    Glen_7 Member Posts: 82
    Dan,
    I have these grills in my home for a/c returns. When I was looking, I didn't see anything of like quality for a better price. They are made of resin so I don't think they are appropriate for floor registers, but they look great elsewhere.
    Glen
  • Brad White_184
    Oh
    Resin- I did not pick up on that. I would not use them for floor grilles then... Resin is not cheap but the price to value ratio just fell in my eyes.
  • DanHolohan
    It's for an AC return.
    And for a young couple of a tight budget. Thanks.
  • Larry C_13
    Larry C_13 Member Posts: 94
    How about a local used house parts place?
    Depending on where they are, many cities in the NE have used house parts stores. They are great places to find new homes for otherwise abandoned fittings and such.
    Larry C
  • mark s
    mark s Member Posts: 12
    grills
    http://www.archgrille.com/
    They are in Brooklyn.
  • Howard Emerson
    Howard Emerson Member Posts: 103
    Craftsman style grills, etc.
    Hi Dan,
    Go here: http://www.crafthome.com/products.htm , click on 'Heat Registers' and go crazy........There's way too many choices and many levels of quality and styles.
    If you're into Craftsman style in general, this is the place to go.
    Regards,
    Howard
