Strange pipe nipple
Mike C_9
Mike C_9 Member Posts: 2
Thanks. You answered my questions. Never used them. I have always used a coupling or a union.
  • Mike C_9
    Strange pipe nipple
    Looking through some old stock, I found several pipe nipples with both left and right-handed threads on the same nipple. They are 3/4 x 3" and 1/2 x 2 1/2". It appears that they could have been used between two fittings to draw them together. Any ideas where they might have been used?
  • Howard Emerson
    Howard Emerson Member Posts: 103
    Ever do any gas plumbing?
    http://www.plumbingsupply.com/leftright.html
    This may be what they are given the description.
    HE
  • L & R nipples
    are very common in my area as many CI rads-on-feet are LH tapped.
    I keep quite a few in stock.
    Dave
  • MikeyB
    MikeyB Member Posts: 696
    L&R nipples for use with L&R cpgls for gas line repair work, You would have to use them instead of unions. Have used quite a few in N.Y
  • TJ_5
    TJ_5 Member Posts: 71
    strange nipples
    Could also be mud drum nipples
