Strange pipe nipple
Mike C_9
Member Posts: 2
Thanks. You answered my questions. Never used them. I have always used a coupling or a union.
Strange pipe nipple
Looking through some old stock, I found several pipe nipples with both left and right-handed threads on the same nipple. They are 3/4 x 3" and 1/2 x 2 1/2". It appears that they could have been used between two fittings to draw them together. Any ideas where they might have been used?0 -
Ever do any gas plumbing?
http://www.plumbingsupply.com/leftright.html
This may be what they are given the description.
HE0 -
L & R nipples
are very common in my area as many CI rads-on-feet are LH tapped.
I keep quite a few in stock.
Dave0 -
L&R nipples for use with L&R cpgls for gas line repair work, You would have to use them instead of unions. Have used quite a few in N.Y0 -
strange nipples
Could also be mud drum nipples0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
