Latest Project
KCA_2
Member Posts: 308
I don't usually post projects but have seen some of yours in the past. I think that my guys really did a good job on this one.
The Owner got what he paid for..
Just a Kudo's to the guys tha believe in the "Dead Men" motto
:-) Ken
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=341&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
:-) Ken
:-) Ken
very nicely done
make sure you use this picture to show potential customers what kind of quality they can expect from you and your crew.0 -
Nice job,
Ken. I like the document holder.
Will they be able to remove the indirect without removing some of the piping? Even though those SuperStor's are guaranteed for life...........
Plenty of room
It's a little misleading. There is at least 4 feet between the superstore & the wall. Taking it out would be easy enough. Got to admit though,. I never had to replace one before. However,. We're going with Triangle tube for the next few projects.
Thanks for the kind words All..
:-) Ken
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional":-) Ken0 -
Plenty of room
This is what happens when you click the mouse twice !!
:-) Ken
:-) Ken0 -
Looks Great!
I like the obvious attention to detail on getting all the pipes insulated, etc.
I do have question re: the zone valves though. Is that Taco one of the new variable-speed models, are you using a PAV, or is the system simply happy having 6 zones on one pump?0 -
Just a 007
As far as the secondary circulator goes it's just a 007.. Nothing fancy.
The design is special though. I use the side arm as a kinda buffer. The domestic heats up to +- 180 and,. because we put over a mile of tubing in this 2800 sqft home, we run the system at pretty low temps. I can pull the BTU's I need out of the domestic, on a 45-50 deg day,. toheat the home without the boiler comming on.
The btu/sqft/deg day factor on the designs has been between,. 3.8 ond 5 depending on customer usage.
Good factor huh?
:-) Ken
That's pretty nifty!
It's interesting that the tank contains enough hot water to keep the house warm all day... a back of the envelope calc shows something like 40kBTU of usable energy... ah, the things we can do once the envelope is tight and well insulated.
Historic considerations prevented me from being much more efficient than 5BTU/(ft2 x DD)... oh well. I hope the Vitosols will make up for that by reducing the hot water heating needs.0 -
your right
> insulated.
> BTU/(ft_sup_2_/sup_ x DD)... oh well. I hope the
your right
> insulated.
your right
About the 40K or less.. But that's enough to maintain a given area for a while on a semi warm day.. 50 or so deg..
keeps the boiler from cycling.. and the homes are pretty tight. Most of our customers keep the stats aroud 65 +-
:-) Ken
PS this pic is for the gentleman who was concerned about removing the WH
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
