Setting Anticipator
Paul Fredricks_2
Member Posts: 35
> I have a probloem that I have tried to fix by <BR>
> adjusting the anticpator. Unfortunatly I have my <BR>
> theromstat set at 60 degrees and the room heats <BR>
> up until 70 degrees, I have turned it down to 50 <BR>
> but it keeps heating. Do I need to replace the <BR>
> thermostat? <BR>
<BR>
> thermostat? <BR>
<BR>
Anticipator/ Too much heat
I have a probloem that I have tried to fix by adjusting the anticpator. Unfortunatly I have my theromstat set at 60 degrees and the room heats up until 70 degrees, I have turned it down to 50 but it keeps heating. Do I need to replace the thermostat?0 -
Anticipator
That is quite an overshoot... If you can measure the anticipation on the stst or at least lower your stats antic. setting a point or 2.0 -
Sounds to me...
Like you have a different problem. Either the thermostat is bad or there is a stuck zone valve or flo check. I'd guess it's not the thermostat, but someone qualified should check the system out.0 -
Not anticipator
It doesn't sound like you have an anticipator problem, not with that kind of overshoot. As far as the thermostat, if it is a mercury type, make sure the back plate is level and may need to be calibrated. Is the radiation always warm? If FHW could be bad flowcheck, zone valve etc leaking by. Sounds like you need a tech to look at.0 -
It is a mercury type thermostat that has been in use for about 8 years, never had this problem before, The radiators do appear to be warm most of the time.0 -
Termostat
Probably not the thermostat. Check for stuck zone valve or stuck circulator relay.0
