New boiler water level
Long Beach Ed
Member Posts: 1,211
Sounds fine to me. Of course it would depend on the size and tightness of the system and the amount of time the boiler was operating. Even with all new steam vents the loss you describe would sound about right.
Now that you have a new boiler it would be a good time to go through the system, replace the ancient steam vents and make sure the mains are all properly vented.
Of course you plumber did all that already, right?
Long Beach Ed
Long Beach Ed
I just had a WM Steam Boiler installed. I leave the glass tube filled half way. In one week it lost about 1/4 inch on tube. Does that sound normal?0 -
my cousin is a plumber, he installed it. He checked my mains, Gortons. they were good. He told me to replace all the air vents on the rads which i did myself, not a problem.0 -
Since steam is an open system I expect some small amount of water loss, through vents, valves, LWCO blowdowns, etc.0 -
great my older utica had a leak above water level. must have been like that a while, i was adding more water year after year so now im paranoid.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 853 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
