Herman Nelson Immured Wall type radiator
Jon_17
Member Posts: 1
Does anyone have drawings/specs showing where the valves and traps are located in the basement area for the invisible "Immured" Herman Nelson residential wall radiators?
Somewhere
between the risers and the mains. It's really the installer's discretion. I think the bottom grille could be removed on these units though; check in there for the valves and traps if you haven't already.
If you find there aren't any traps or other devices on the return connections at all, it's an Orifice system.
