Counterflow steam ( Ron Jr. )
Rich Ferris
Member Posts: 72
Ron,
Nice job as usual. I like to see your jobs posted here. I can't help but notice that almost every job shows that the chimney connection from the old boiler has staining on the walls from the condensation when the boiler gives up the ghost. Not on this one at least. I do have a pet peeve with your oil filter installs. They always seem to be hanging in the air via soft copper tubbing. Do you actually service these units after they are installed. Having the filter unsecured would seem to allow for leakage at the fitting that are under extra stress when changing the filter cartridge annually. If you have a reason for this that I'm missing I'd like to hear it. I'm not trying to start something I'm just curious. Your piping is dead on and clean and I wouldn't want to have the jobs that you get the fortune or misfortune of doing but they always look a 1000 times better than when you got there.
Rich
Rich
This was a mess
The homeowner told us the system banged for so long , they just got used to the sound .0 -
Burnham V83
with a probe and feeder . We had a 67 float cutoff , but we saw the lady of the home having alot of trouble getting up and down the stairs . So I switched it to a probe .
Counterflow steam can get a little tricky . I almost forgot the equalizer pipe , thinking I was making one already ( the higher pipe ) .
This install was done by me and Kenny . Way too much work for 2 guys in one day , we still caught some grief for leaving the old boiler in the basement . Can't please everyone all the time
caught grief?
My god, they have no clue what was involved to get it as far as you did. Beautful work!! Bet they can't sleep now because it's to quiet..:) Keep up the nice work!!0 -
That is so
lovely!Retired and loving it.0 -
Ron.
WOW ! Chris0 -
Would?
it have been better to get the old boiler out or get the job running? Has management ever humped a boiler downstairs or has it been so long they forgot?
primo piping arrangement
first class steamfitting job0 -
Those old National-US Sunrays
are quite heavy. Better to get the job running and come back the next day to pull the old one out. Better yet- have a couple of the other guys pull the old one out ;-)
Nice job, as usual. BTW, the old Watts LWCO belongs in a museum.
Nice installation, Ron
Beautiful pipework!
Noel0 -
Always nice to see your jobs Ron
Clean and tight!! I second steamheads idea, other guy's go back and pull the old one. Tim0 -
Management
If working for Ron's comapny (a bigger company) is like the one I once worked for you are nothing but a number to them. All they see is the bottom line for that day and what they can make tomorrow. Get hurt, they don't care they find some other sap. Ron is too talented to work for someone like that. I hope I am wrong and his company is different.
Leo0 -
I think
we'll be back to change a 3/4 black pipe being used as return . Looked pretty clogged up and it's way too small for a 2 inch gravity return main .
We worked non stop from 9 to after 4:30 . No time for lunch , coffee went cold before I got to it . I didn't wash my hands till we were done . The good news is I lost 5 lbs from working
Thanks alot lchmb .0 -
Hey Rich
Yeah , I notice alot of chimney stains on the boilers we replace . You should see one that has a Blueray running for a good amount of time . I'll see if I can find a pic .
We used to hang the oil filter on steel fittings and pipe , but we had way too many thread leaks . We tried to minimize the threaded fittings on the oil line and not many callbacks so far . On this job the oil line is actually pretty secure and the filter is protected betweeen the boiler and burner . I wonder if a bracket is made for the type of filter we use ?
Thanks alot Rich0 -
I've been
with my company over 12 years , and my former company almost 10 years . 12 years ago , maybe even 5 , we coulda done the whole job and removed the boiler too . Putting myself in someone elses place , I guess I would have to question why the boiler was left behind when we used to finish the whole job in the past . But there's only so much abuse I can put my body through on a given day and come in the next to do it again . I guess it's sort of a blessing when these jobs fall on a Friday .
Thanks guys .0 -
Thanks Bob
The difference between a first class pipe job and a thrown together nightmare is usually $100 in more parts and 1/2 hour more work .0 -
Thank you
Dan and Chris . Steam is a nice change of pace and I enjoy installing the systems . Except for the heavy parts .0 -
I'm going back Monday
with Kenny . We were supposed to change the thermostat too , but brought a low voltage digital with us . This is only the 2nd steamer in the hundreds we've replaced that has a line voltage thermostat running the show .
Thank you Noel and Tim0 -
junk
the mechanic should not have to carry out the junk-------unless it is BRASS or COPPER or MONEL. then its ok.0 -
Defining Quality Once Again, Ron Jr.!
Another encyclopedic entry into how it should be done. Your work is a visual treat, Ron. I wish that I could spend at least a weekend in a house so heated.
Certainly I hope those that matter appreciate what you do."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
good show
And a steamfitter that knows how to fit pipe properly. and i'm sure you are capable of fitting up flanges without too much trouble. unless you are exhausted and can't read the ruler ! lol0 -
Art...
As usual Ron, a real work of art! Perhaps it's time for "The Found Art of Steam Heat" featuring the works of the pros here!
BTW, Westwood makes filter assemblies with brackets and also sell the bracket and a replacement filter top as separate items. The bracket is an F100-12 and the top is F100-8."Let me control you"
Lost in SOHO NYC and Balmy Whites Valley PA0 -
Superb Quality
Ron, once again you have shown everyone the high quality installs that are done on Long Island. Many oil companies get a bad name for low quality installation but your company does the best work. I am sure you have made an elderly lady very happy.0 -
sweet looking job
Really another great looking job, funny how the counterflow looks funny compared to a normal drop header, good thinking, only one union too. Thanks so much for posting this.0 -
Just curious
I'm just curious Ron but how come two equalizers?
Your work looks nice!
EDIT, never mind! I see now that one is a condensate return and the other is the equalizer.0
