Furnace Messes up T.V. Picture
realolman
realolman Member Posts: 513
are your priorities, man?...... Get rid of the furnace! ;-)
  • Matt_40
    Matt_40 Member Posts: 4
    T.V. and Phone interference
    Any one know why when a furnace comes on it makes the snow fall on the t.v. set. Cable t.v. also has static on the telephone. Feed Back appreciated. Thanks
  • martin
    martin Member Posts: 144
    Interferance
    Check your grounding on the furnaces electric feed, that is if the furnace is newer with electronic ignition
  • Boonierat
    Boonierat Member Posts: 58
    TV interference
    On oil burners it might be a good idea to look over the porcelain insulators on the electrodes.
    Hairline crack in the porcelain can show up on a TV screen.
    Good luck,
    Nels
  • Ed_26
    Ed_26 Member Posts: 284
    TV
    Also check the ignition transformer... have had to replace them to stop the interference. (insulation breaking down seems to be the culprit)
  • Shoot the TV...
    get a good book, and curl up next to the heat register :-)
    Problem solved... NEXT!!!
    Happy Gnu Ears to ya'll.
    ME
  • Al Corelli_2
    Al Corelli_2 Member Posts: 395
    Grounding
    Check that the blower motor case is grounded correctly. I have seen situations where the ground path found its way through the bearing and created all sorts of RF noise.
