cast iron boiler repair
Weezbo
Weezbo Member Posts: 6,231
  • jxhank
    jxhank Member Posts: 1
    Is there an epoxy to patch a pinhole in a cast iron boiler, or what would be suggested????
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    You could attempt JB Weld. It will handle the heat, but I wouldn't have much hope for the repair to be very long-lasting. Clean the area VERY well before applying. Stiff wire brush followed by a wipe with a solvent like naptha.
  • Al Corelli_2
    Al Corelli_2 Member Posts: 395
  • Dave_74
    Dave_74 Member Posts: 13
    Repair of Pinhole in Cast Iron
    If it is truly a pinhole, it is common to "pean" the area to move the cast iron together to close the pinhole. If it is a crack, it is not repairable.
    H.B. Smith, for example, has a factory technical bulletin for peaning a pinhole, often due to a defect due to sand from the mold process.
    It is worth a try.
  • Jim_64
    Jim_64 Member Posts: 253
    pinhole
    If it is really a pin hole sharpen a pencil and tap it ino the hole with a channel locks on the flat. Lead pencil will expand and seal. graphite reacts with the water and iron and seals. Obviousy break the point off ans replace the jacket.
  • mark_107
    mark_107 Member Posts: 1
    crack in the cast iron on my boiler
    is it safe to patch a crack on a cast iron boiler. my landlord said he "cold patched it" what is the best recommendation in this situation.
  • Al Corelli_2
    It Depends...
    One would have to see the actual crack to determine temporary repairs.
  • crack and/or pin hole
    Who pays for heat?
