cast iron boiler repair
Weezbo
Member Posts: 6,231
Is there an epoxy to patch a pinhole in a cast iron boiler, or what would be suggested????0 -
You could attempt JB Weld. It will handle the heat, but I wouldn't have much hope for the repair to be very long-lasting. Clean the area VERY well before applying. Stiff wire brush followed by a wipe with a solvent like naptha.0 -
pinhole
A good pro can probably do it without chemicals.
Repair of Pinhole in Cast Iron
If it is truly a pinhole, it is common to "pean" the area to move the cast iron together to close the pinhole. If it is a crack, it is not repairable.
H.B. Smith, for example, has a factory technical bulletin for peaning a pinhole, often due to a defect due to sand from the mold process.
It is worth a try.0 -
pinhole
If it is really a pin hole sharpen a pencil and tap it ino the hole with a channel locks on the flat. Lead pencil will expand and seal. graphite reacts with the water and iron and seals. Obviousy break the point off ans replace the jacket.0 -
crack in the cast iron on my boiler
is it safe to patch a crack on a cast iron boiler. my landlord said he "cold patched it" what is the best recommendation in this situation.0 -
It Depends...
One would have to see the actual crack to determine temporary repairs.
crack and/or pin hole
Who pays for heat?0
- 125 Chimneys & Flues
- 120 Geothermal
- 169 Indoor-Air Quality
