direct vent question
What is the code for distance a direct vent termination can be from an outdoor pool heater both gas fired.Height and length.Thanks for any help
  • Empire_2
    Empire_2 Member Posts: 2,340
    Only thing I can find...
    "Clearance to each side of the center line extended above or below vent termination of furnace to: a dryer, water heater vent, or other appliances direct vent intake or exhaust is 12". Doesen't say anything about stand alone appliances such as pool heaters.
  • curiousity kills
    curiousity kills Member Posts: 118
    Thank you
  • curiousity kills
    Thanks
  • curiousity kills
    Thanks
    thanks
  • Larry Savino
    Larry Savino Member Posts: 63
    It would be a mistake not to read the installation manual of the direct vent appliance you are trying to vent.
    As far as I know you would have to consider that the pool heater has a fresh air intake and you would have to be at least 4' away
  • Guy_6
    Guy_6 Member Posts: 450
    AND
    Also keep in mind that the exhaust from the DV appliance may have ugly effects on the pool heater's appearance, and eventually structurally.
  • curiousity kills
    &Iguess my concern is the cross contamination from the pool heater to the boiler.The pool heater is two feet below the dv outlet
