What is it?
karsthuntr
Member Posts: 3
No it is not a rolairtrol. I should have put that in my post. :)
What is it?
I have a church with a leaking Burnham V9111A, it is leaking at the push nipples. I had the Burnham rep. out to look at it the other day and he questioned what a component on the system. It is a 180 deg. constant circulation system with two circ pumps. The expansion tank is the old style with no bladder. What you see in the drawing is all there is on this "tank" (for lack of a better term), it is completely insulated so I have no numbers on the tank itself.
So what is it?
http://farm4.static.flickr.com/3079/2781807676_9765d06007.jpg0 -
Does it look like this?
http://www.bellgossett.com/productPages/Parts-Rolairtrol-Air-Separator-For-Hot-and-Chilled-Water.asp0 -
similair to rolairtrol
B&G used to have a non ASME separator "IAF" with 2" or 3" threaded connections, so I think that is what you have.
Not been manufactured for a long time now.0 -
Do you have a link or picture?0
- 167 Indoor-Air Quality
