direct vent question
curiousity kills
Member Posts: 118
What is the code for distance a direct vent termination can be from an outdoor pool heater both gas fired.Height and length.Thanks for any help
Only thing I can find...
"Clearance to each side of the center line extended above or below vent termination of furnace to: a dryer, water heater vent, or other appliances direct vent intake or exhaust is 12". Doesen't say anything about stand alone appliances such as pool heaters.0 -
Thank you
Thanks
Thanks
thanks0 -
It would be a mistake not to read the installation manual of the direct vent appliance you are trying to vent.
As far as I know you would have to consider that the pool heater has a fresh air intake and you would have to be at least 4' away0 -
AND
Also keep in mind that the exhaust from the DV appliance may have ugly effects on the pool heater's appearance, and eventually structurally.0 -
&Iguess my concern is the cross contamination from the pool heater to the boiler.The pool heater is two feet below the dv outlet0
- 167 Indoor-Air Quality
