Gasification boilers
JW_7
Member Posts: 1
I have install over 20 wood gasifiation boiler since last year from 1 million btu's to 100,000 btu's and must say
That Econoburn boilers are best. Yesterday took in 1 500,000 and 3 smaller ones and waiting on 12 more that are in production. Must say Alternative Engery's Econoburn Boilers are the best and the factory services is 2nd to none
are a wood boilers..
gasification boilers? If not other than Tarm what are some good brands... there is a lot of "strange marketing on the web" I0 -
wood boilers
Do some reading on hearth.com, in the boiler room.
EKO, econoburn, Tarm Greenwood etc etc are all discussed there. Lots of great info. And no, not all wood burners are gasifiers
Chris
Not all are gasification
Gasification is a process whereby the wood is "cooked" to a point where the gasses and smoke are emitted and then burned via the injection of high temperature oxygen bearing air into a special "heat chamber". This area of the boiler is made to hold heat in rather than transfer it to the fluid. The actual heat transfer occurs in other areas of the boiler that are made for that purpose. Econburn's website has a good little video that shows what and how it happens. Typically, a gasification boiler will deliver better efficiency and far less pollution than a non-gasification unit will. Smoke = wasted BTU's.
www.alternativefuelboilers.com0 -
JW
Are you using any kind of additional storage or buffer tank on any of those jobs? If so, what?0 -
Quite a difference
in performance difference between gasification and non. I have installed numerous brands of both styles.
On the gasification side I have installed Tarm, PK Pyro, Atmos, EKO Vimar, and one pellet gasification style. On several jobs, including my own the gasification style replaced non gasification brands. My EKO replaced an older Royall, both pressurized indoor installation.
Without a doubt the gasification units burn cleaner, hotter, and consume less wood doing so.
Like any high efficiency device they do require more attention. The wood needs to be dry, no green or wet wood allowed. Generally they have smaller fireboxes requiring smaller wood size. Cleaning is important to keep HX at it's best.
Buffer tanks are a must, in my opinion. Unless you can standby all day and night to stoke them or keep a consistent load on them.
Gasification units seem to be much higher quality steel both in thickness and grade. All the brands mentioned above have high quality welds, assembly, and sheetmetal jacketing. Most gasifiers have some sort of microprocessor control, often with OD reset, variable speed blower control and overheat protection means.
Of course price, and weight
go up considerably, compared to tin drum OWF's.
hrBob "hot rod" Rohr
Thanks
i will look into them for my customer. Do they have one that has a gas burner to start the process of burning then will shut off after the wood gets going?
kpc0
