mouse turds on Munchkin HX?
R. Kalia_4
Member Posts: 18
My first year with a Munchkin T80, so I've been monitoring efficiency. Over time, nat gas usage (therms per degree-day) has increased 20%. Now the weather is the same as last November, and the Munchkin is using 20% more gas per day than in November.
I opened it up today. The HX has a large number of little loose pellets on it (see photo). They are dark gray, irregular pellets less than 1/16" in size. Some crumble when squeezed, others are quite hard.
Now I'm an amateur and I've never opened up a boiler before. (Yes, I was able to vacuum and clean and put it back together, it seems to be running fine and not leaking, although I haven't had time to measure efficiency yet.) So my question is, are these pellets normal?
Also, there is some white powder, coming from the ceramic backing. Is this normal?
Interesting that the original mouse turds thread has been completely erased after someone added a new post recently. It had useful information.0
