Adding radiant system to existing boiler system
is do a modified primary/secondary loop using another zone valve. Run a short loop out from the new zone valve and run this to the return on the boiler....in this loop put in two tees. off the supply pipe in your mixing valve. Of the out let sid add in the circ.. To wire it you use a simple circ. relay(taco sr501)wire your t-stat to that and the end switch gets wired to the zone valve control tstat location...let me see if I can draw and post a pict...kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
