pump curves
Brad White
Member Posts: 2,399
Along the bottom of the chart, running from left to right is the flow, usually in GPM. (Litres in metric measurement.)
Along the left side, running from bottom to top is the head or pressure differential imparted by the circulator. This is usually in "feet of head". (Meters or Decimeters in metric measurement.)
That area above and to the right of these indexes is the "field" on which the circulator curves are plotted.
The "curves" typically run from upper left to lower right and represent the flow and pressure measured at a constant speed (RPM). You can see how a given circulator will produce less flow against a higher head or more flow against a lower head.
Your SYSTEM curve (over which you have some control) runs from the lower left corner (zero flow = zero head, make sense?) up to the intersection with your circulator curve.
The system curve is NOT part of the circulator curve but is something you plot yourself to check your system performance and to assure yourself that you selected the right circulator.
There is more to it than that, but this is a general description which I hope well start you on a path of self-discovery.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
pump curves
anybody up for giving me a short course in understanding & reading pump curves? Just small heating boiler pumps. Thanks Jack0 -
Pump Curves
Hello Jack. Please send me your mailing address and I'll send you a training CD - there is good information on it (pump and heating basics).
My E Mail address is steve,thompson@wilo-na.com0 -
have you some recent information on the Mini circs?
i have a perfect small home to exemplify the reasoning of the smaller circs....0
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
