Pri/Sec or bypass?
clammy
Member Posts: 3,242
If it is a gravity conversion i would do a pri sec with constance circ and a reset for the system water temp.I would watch out for all that cold water return from shocking and or causing flue condensation .Did you look into a modulating condensing boiler they love those types of application and work great with constance circ lower supply temp.In either case i would look at primary secondary piping or something with a system by pass to keep those retrn temps up a little bit .peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Well I just ordered the boiler from Don Park, now its just the changeout. I really want to do primary/secondary but the space is real tight. Is the benifit of pri/sec over bypass worth the extra hassle that will be had making it fit? Boiler is Weil-McLain CGa series with elec. ign..0 -
Michael
What type?
Radiant?
Baseboard?
Radiators?
other?
Robert O'Connor/NJ0 -
Cast iron rads on a gravity conversion. Space is tight, and with three supplys and three returns it makes it even harder.0
- 167 Indoor-Air Quality
