Pri/Sec or bypass?
clammy
clammy Member Posts: 3,242
If it is a gravity conversion i would do a pri sec with constance circ and a reset for the system water temp.I would watch out for all that cold water return from shocking and or causing flue condensation .Did you look into a modulating condensing boiler they love those types of application and work great with constance circ lower supply temp.In either case i would look at primary secondary piping or something with a system by pass to keep those retrn temps up a little bit .peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
  • Michael Rogers
    Michael Rogers Member Posts: 29
    Well I just ordered the boiler from Don Park, now its just the changeout. I really want to do primary/secondary but the space is real tight. Is the benifit of pri/sec over bypass worth the extra hassle that will be had making it fit? Boiler is Weil-McLain CGa series with elec. ign..
  • Robert O'Connor_12
    Robert O'Connor_12 Member Posts: 728
    Michael
    What type?
    Radiant?
    Baseboard?
    Radiators?
    other?
    Robert O'Connor/NJ
  • Michael Rogers
    Cast iron rads on a gravity conversion. Space is tight, and with three supplys and three returns it makes it even harder.
