Old Gravity Hot Water heating system
Steamhead (in transit)
Member Posts: 6,688
the system pressure isn't that much greater, you shouldn't have trouble with leaks.
The right way to size the new boiler is with a heat-loss calculation. With a properly-sized boiler the radiators won't get quite as hot, but they will heat the house properly on design day.
Why buy more boiler than the house needs?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Old Gravity Hot Water system
I have a customer who is going to change an old gravity hot water system to a new forced hot water.Will the cast irom radiators leak. Also how would I size my boiler from the sizes of the radiator.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
