Steam System pipe hammer
Carl Weber
Carl Weber Member Posts: 1
I have a LP steam heating system w/ 5" hg. vac. on the return side. A contractor piped a unit ventilator witha 12" rise in the cond. piping after the therm. trap. I assume that this will cause significant hammering problems, especially if the vacuum pumps go down. What is your opinion?
Thanks - Carl
