Installing a waste oil heater
Biged, you should look into the bench tank setup that Clean Burn has. The heater sits above the tank on steel supports and also passes code , 5' from tank makes service easy as they need allot of service compared to other fuels.
Hope this helps John@Reliable
  • Biged
    Biged Member Posts: 117
    I am going to bid on a job to install a waste oil heater. this thing is going in a building about 20'- 25' high and weights 400lbs. what kind of a support am I talking about to carry this weight? This is the first one this size.
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    hanging a heater
    You give information that is way too general and lacking way too much information to give you a definite answer. Most manufacturers give information on supporting their units. One would need to know things like what are you hanging it from, type of materials, vibration protection, etc. Sounds more like a question for a structural engineer.
    400# isn't a lot of weight if hung from several points. Consult the manufacturer's recommendation and hang accordingly. If it's bar joist construction, remember this. The bottom cord of the joist is NEVER designed to carry weight. Hang from the top of the joist only.
  • Biged
    This building is
    new with I beam structure and I did look at the installation manual and all it said was use 4 - 1/2" rods.
