Any experience with this Azel supply/return temp gauge?
D107
Member Posts: 1,944
as well, since I don't have the wells to insert into in my setup. And I should (?) put some black electrical tape or paint pipe black at point of measurement from copper pipes?
This setup actually comes out a bit cheaper than buying two different thermometers and has other advantages as well.
Thanks,
David
Thanks,
David
single digital gauge, two probes
this is the link:
http://www.accentshopping.com/product.asp/s/ie6wb836nyzixmundszniayis2Yblbofdvg234029/&P_ID/149655/#REVIEWS
Probe can be strapped on pipe or inserted into wells. I would wonder about the accuracy of the read. Using it to measure Delta T.
Thanks,
David0 -
i use
model DS 60 P. perfect application for delta T. very accurate (based on 10K thermister)0 -
I own three
and find them perfect for Delta-T as Glen said. Indoor-outdoor, boiler in and out, system in and out. As Glen noted, 10K Ohm thermistors are quite accurate. Same sensors as come from Tekmar that I can tell."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
attach
to bare pipe for best surface contact. (not sure how thickly you paint) and then wrap with a bit of fiberglass pipe insulation to completely isolate sensor. And the tekmar 071 sensor can be used if the original sensor goes funky on you.0 -
Glen is correct
Forget the "paint thing"- that applies to radiant heat measurement, not contact (conduction). Take a fine mill file and remove the surface finish to bare metal. If you have heat conductive paste (a mix of petroleum jelly and aluminum powder, near as I can tell), a schmeer of that will make for good contact.
The sensors have a concave side designed to snug against pipe wall radii, you will see.
Personally, I wrapped mine in Armaflex insulation tape, secure it with a stainless steel band clamp, then over-insulate with full Armaflex and maybe some thin plastic ties."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
- 167 Indoor-Air Quality
