Convert from S/W to strait heat.Honeywell R8182
Smokey
Member Posts: 3
Only that the boiler water is always hot, the tempeture is set between 160-180.and the thermostat controls the circulator.Iwant to install a freestanding water heater and use the boiler just for heat.
Honeywell R8182H
Want to convert boiler from summer winter hookup to strait heat.What wires do I jump out or switch0 -
I looked at the wiring/installation instructions for the R8182 and didn't see anything about summer/winter. Can you tell me more?0 -
Smokey
My guess is that your boiler has been sitting around for a few years @ 160*, if you try going cold styart now you are likely to find water dripping from the boiler where it contracted and hasn''t done so in years, I would sujest you just turn it down to 130 and see what happens if it drips you can turn it up ten degrees at a time until you hit the magic number.0 -
No, my boiler runs every day,for heating and hot water trough a domestic water coil.What I want to do is use the boiler only for heating in the winter and not have it running all year.I'll get my hot water from a seperate hot water heater0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
