In- wall cast iron radiators
Wanda
Member Posts: 1
We currently have box in-wall mounted cast iron radiators, about 6 inches aquare, I guess, with a steam heat system. We are replacing our system and changing to a hot water one but would like to see if we could find radiators that would fit into our wall spaces and provide the hot water heat. I really hate baseboards. Any suggestions????
Burnham makes them......
....check out www.burnham.com.
You have to be careful when sizing the radiator, as it's output gets derated when recessed into a wall. I believe the web site lists the percentages.
Starch
Edit: Here's the link directly to the radiator pdf file.
Burnham Radiators0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
