In- wall cast iron radiators
Wanda
Wanda Member Posts: 1
We currently have box in-wall mounted cast iron radiators, about 6 inches aquare, I guess, with a steam heat system. We are replacing our system and changing to a hot water one but would like to see if we could find radiators that would fit into our wall spaces and provide the hot water heat. I really hate baseboards. Any suggestions????
  • John Starcher_4
    John Starcher_4 Member Posts: 794
    Burnham makes them......
    ....check out www.burnham.com.
    You have to be careful when sizing the radiator, as it's output gets derated when recessed into a wall. I believe the web site lists the percentages.
    Starch
    Edit: Here's the link directly to the radiator pdf file.
    Burnham Radiators
