Condensate neutralizer set up
cattledog
cattledog Member Posts: 60
Grainger Item # 6MC69
  • andy_21
    andy_21 Member Posts: 42
    condensate neutralizer set up
    Looking for a condensate neutralize set up. did a search & found the thread, but pics wouldn't come up. anyone have a pic they could post
    Thanks
  • Mars_3
    Mars_3 Member Posts: 65
    Mike its realy simple
    All you need is two tees of pvc, a cap for the bottom and a clean out for the top. I use 3" by 1" pvc tees and have found that this will work with most boiler manufactures condensate traps. A simple uni strut clamp to secure the trap to the wall and run the upper tee to the floor drain and the lower tee to the condensate trap, then fill the trap with marble chips replace the cap and let her rip. the only thing to keep in mind, is that the home owner needs to keep an Eye on the level of the marble chips in his Trap.
  • andy_21
    Thanks!
    hot_rod Member Posts: 26,631
    Another homemade
    I use a pluged type closet flange as the bottom for a good base. A Fernco rubber cap on the top to open, inspect, and replenish.
    I drill, thread, and glue mip X PVC ells into the side for in and out connections.
    hot rod
  • Paul B_5
    Paul B_5 Member Posts: 60
    Can you guys submit a Pic please of your DiY units of these condensate traps/neutralizers
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 742
    here's one
    This is what the Lochinvar factory supplies and is also supplied by at least one other manufacturer. Surprisingly simple and works just fine. pH is about 3 to 4 going in and around 7 coming out.
  • Larry (from OSHA)
    Here's one
  • cattledog
    The neutralizer which Larry has shown is available through Grainger and is also listed as available from Triangle Tube.
  • Paul B_5
    Re :neutralizer..Thanks guys its nice to see some differant set ups
  • nosirra1Arrison
    nosirra1Arrison Member Posts: 58
    DIY
    Heres one of the vertical DIY type
  • Jim Franklin
    Jim Franklin Member Posts: 170
    Axiom condensate neutralization tank (NT20)
    Have a look at the NT20-A in the products section.
    http://www.axiomind.com/
  • Greg Hunsicker
    Greg Hunsicker Member Posts: 3
    Neutralizer Grainger Part Number
    What is the Grainger number that you say is available?
