Condensate neutralizer set up
cattledog
Member Posts: 60
Grainger Item # 6MC69
condensate neutralizer set up
Looking for a condensate neutralize set up. did a search & found the thread, but pics wouldn't come up. anyone have a pic they could post
Thanks0 -
Mike its realy simple
All you need is two tees of pvc, a cap for the bottom and a clean out for the top. I use 3" by 1" pvc tees and have found that this will work with most boiler manufactures condensate traps. A simple uni strut clamp to secure the trap to the wall and run the upper tee to the floor drain and the lower tee to the condensate trap, then fill the trap with marble chips replace the cap and let her rip. the only thing to keep in mind, is that the home owner needs to keep an Eye on the level of the marble chips in his Trap.0 -
Thanks!0 -
Another homemade
I use a pluged type closet flange as the bottom for a good base. A Fernco rubber cap on the top to open, inspect, and replenish.
I drill, thread, and glue mip X PVC ells into the side for in and out connections.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Can you guys submit a Pic please of your DiY units of these condensate traps/neutralizers0 -
here's one
This is what the Lochinvar factory supplies and is also supplied by at least one other manufacturer. Surprisingly simple and works just fine. pH is about 3 to 4 going in and around 7 coming out.0 -
Here's one
The neutralizer which Larry has shown is available through Grainger and is also listed as available from Triangle Tube.0 -
Re :neutralizer..Thanks guys its nice to see some differant set ups0 -
DIY
Heres one of the vertical DIY type0 -
Axiom condensate neutralization tank (NT20)
Have a look at the NT20-A in the products section.
http://www.axiomind.com/0 -
Neutralizer Grainger Part Number
What is the Grainger number that you say is available?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
