no heat in the house
Weezbo
Member Posts: 6,232
I have a crystal ball. it is unfortunately in my shop truck at the momment. However lets make sure there is power from the circuit breaker to the heating equipment,fuel available to allow it to run, and some more information as to what type of heat is currently installed and it's fuel of choise.
why is there no heat in the house??
how the hell do we know!
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
Not being there
to check electronics it is probably air bound, not being able to see the system I can't tell you why call the last guy whom woeked on it.0 -
No Heat
Without knowing what type of system, I would suggest contacting your source of fuel. They may have a service department or names of service contractors. Hope this helps.0 -
Because the \"Heat\" have not been called, Look under \"Police\" and
try that #0 -
see: \"air vent on my boiler\" below
See his earlier post below. He's having a bad day today.
(Tomorrow should be better I hope John!)
John's boiler air vent is leaking, and his boiler bressure is down to ~6 psi, he recently(?) had x-tank, aquastat & circ changed. It appears the radiators/baseboards are airbound and needs to be purged plus it is not clear how much water is currently in his boile, hense recommendation to shut its power down till a service guy could look at it and replace the vent, refill & purge.
Speculating: the air bind is due to air coming out of replacement water following circ/tank change (+ from makeup water due to air vent leak?)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
