Munchkin F10
tom_49
Member Posts: 267
Thanks for the replys guys.
I'll be contacting factory tommorrow am. If this is ongoiing problem, maybe I can talk HTP into upgraing the control. I wasnt aware that the new one have auto reset after F10.
I'm not sure, but I think the wind was NE the other night, the same direction the vent is facing. Hmmmmmmmm.
munchkin F10 fault
I had a munchkin 140m go into f10 fault ( flame sensing ) twice within 7 days. Both days were VERY windy.
I checked everything out the unit looks OK. Its been running for 7 months.
I dont know if the wind caused this problem , or is it a coincidence?
Any thoughts.
Thanks Tom0 -
F10
I have had numerous F10 and I noticed it was windy when they occurred. Did you set your Munchkin up properly with a CO tester? The company techs say that it is important. I have set up all that I have installed and still got F10 on windy nights. The new controls will automatically reset after an hour of F10. They are expensive to replace though.0 -
F
If you really think that the wind has factored into the F10 fault, consider the venting:Call the factory and find out what your options are for possibly changing the vent terminations so that the wind will not be quite as aggressive toward them. As a matter of fact, FAX them a quick sketch of how they are terminated now with a note about the conditions of the F10. 508-763-4909 is the fax line into tech.0
