Tekmar rep bailed out!
I just finished 3 projects with 8, 11, and 14 RMB's. Where are you located?
  • Rep. bailed out on this project.
    I have a system in which I had planned to use a mod/con boiler with outdoor reset; and 23 Taco radiant mixing blocks, with in-slab and wall sensors tied to remotely located thermostats(boiler room), functioning as set-point controllers. Tekmar rep says "no can do"; I think I need a different rep to talk to!
  • Youngstown, Ohio
  • John_Barba
    John_Barba Member Posts: 166
    Grumpy --
    Have you talked to the Taco rep yet? Or call out tech services department for help...
    JMB
  • Taco is Tops
    Haven't call Taco yet, but I am planning on doing so Monday. I'm glad to see you aboard with Taco John.
    Grumpy
  • Paul Rohrs_4
    Paul Rohrs_4 Member Posts: 466
    I'm curious as to how many mix temps you are supporting?
    That is a lot of RMB's...so now the Taco rep can afford new BVD's PDQ.
    Regards,
    PR
  • ALH_4
    ALH_4 Member Posts: 1,790
    RMB's
    I agree, that is a lot of RMB's. Is it constant circ with individual mix temps for each zone? That's probably the ultimate in comfort, but would use more electricity than 2 or 3 mix temps and zone valves. Just curious about the control strategy.
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    23 RMB's, wow. that's nice. I would love to see that set up. Of course you can call me, or any technical support engineer here at Taco for help. Look forward to talking with you.
    Joe Mattiello
    Taco Comfort Solutions
  • Jed_2
    Jed_2 Member Posts: 781
    23 wall sensors, with remote stats
    Begs further ???? What's the building? What's the load per t'stat (RMB's are good for up to 120MBH; cost effective?)? Is there a more cost effective strategy. Why the RMB's, although they are great products?
    Jed
  • Tim Lindstrom
    Tim Lindstrom Member Posts: 42
    I prefer Taco Bell
    Couldn't resist
