Pool area
Need help locating a manufacturer of baseboard or radiator that can be installed in a pool area, any ideas ????
Shaun Anderson
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    Slant Fin used to, and maybe still does, make a baseboard with an extruded aluminum casing. Very nice, but pricey
  • Shaun Anderson
    Shaun Anderson Member Posts: 164
    thank you
    I will give them a shout.
    Shaun
  • Harold
    Harold Member Posts: 249
    If you are still at the stage before drywall, you could embed radiant in the wall.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Heat the air Grass hopper...
    And keep it about 2 degrees hotter than the water and you won't have to replace the sheetrock every 2 years...
    Install electric windows, virtually eliminating their heat loss, raising the MRT, and heat it with a candle...
    Copper, steel and aluminum mixed with chlorine gets UGLY in a short while.
    ME
  • Empire_2
    Empire_2 Member Posts: 2,340
    Dont' forget,
    I would want to control the RH% also. Dectron Equipment is rather expensive, but we use them in all types of applications. Ceder enclosures, Glass, etc...
    Mike T.
