Radiator Repair
I have sealed 2 radiators simply by putting salt where it is leaking between the sections, without taking apart the radiators. One radiator was forced hot water, and that leak has been sealed for years now. An old timer showed me that trick. Bob Gagnon
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
    Jamie Hall Member Posts: 26,847
    Drippy radiator
    As some of you may remember, I have a lovely vapour steam heating system -- works fine, and I wouldn't change for the world. However...
    There are a couple of radiators which leak. I would like to keep the old ones, as they fit their locations and I can't get new ones the same size and pattern (yes, I've looked!).
    And I wonder. I don't know whether the old ones are the type with a tapered nipple between sections, or just a machined fit. However, assuming I can get them apart without destroying them, has anyone any experience in cleaning up the mating surfaces and using a liquid high temperature gasket material, such as the RTV silicones used in automotive engines, to re seal them?
    Or any other suggestions?
    Jamie
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    I like the RTV idea...
    That red gasket stuff for automotive gaskets I would think would stand up to the temperatures and thermal cycling. No direct experience, just the nature of the application and similarities between the two. The material would absorb any tolerances from the ground push nipples I would think.
    Definitely worth a try!
    If Steamhead, Mad Dog or others chime in, I would defer to them in a heart-beat.
    My $0.02
    Thank you! I'll give it a try, and let you all know how it worked...
