possible causes of Laars lock-out??
Timco
Timco Member Posts: 3,040
No doubt you are correct. That was just my best guess. I will check out the mfg date tomorrow & put a call in to Laars if I can't find anything wrong...any other suggestions / opinions are appreciated!
Tim
Just a guy running some pipes.
  • Timco
    I have a cust with a EDP 175 that has a new ignitor/sensor assy, and I replaced the thermostatic valve as well. Unit runs great, and never gives any error codes. Once a month or so, HO feels cold and unit says LO. I reset the computer and all is good. It runs & tests very well while I am there. I know if it fails to fire after 3 or 5 attempts this will happen, but it fires first time every time I am there...Any suggestions?
    Tim
  • Tony_23
    Tony_23 Member Posts: 1,033
    How old is it ?
    Look at the board and see what series it is.
    I had 4 that did this and it was a board issue.
  • Timco
    Likely around 10 yrs. I will be back there tomorrow.
    Tim
  • Tony_23
    Not quite
    EDP's and EBP's weren't around in '97, IIRC. 1st one I did was in 2000. Problem boards were '01 & '02 installs for me. Could've been earlier models too.
  • On the right track
    Tim, if the combustion is right on (I'm sure you already checked) and your DC microamps flame signal is right, and steady, I would suspect the board, as well.
    Cross contamination of the air supply is also a possibility.
    Noel
    603 335 6300 ex 514
