possible causes of Laars lock-out??
Timco
Member Posts: 3,040
No doubt you are correct. That was just my best guess. I will check out the mfg date tomorrow & put a call in to Laars if I can't find anything wrong...any other suggestions / opinions are appreciated!
Tim
Tim
I have a cust with a EDP 175 that has a new ignitor/sensor assy, and I replaced the thermostatic valve as well. Unit runs great, and never gives any error codes. Once a month or so, HO feels cold and unit says LO. I reset the computer and all is good. It runs & tests very well while I am there. I know if it fails to fire after 3 or 5 attempts this will happen, but it fires first time every time I am there...Any suggestions?
TimJust a guy running some pipes.0 -
How old is it ?
Look at the board and see what series it is.
I had 4 that did this and it was a board issue.0 -
Likely around 10 yrs. I will be back there tomorrow.
Not quite
EDP's and EBP's weren't around in '97, IIRC. 1st one I did was in 2000. Problem boards were '01 & '02 installs for me. Could've been earlier models too.0 -
On the right track
Tim, if the combustion is right on (I'm sure you already checked) and your DC microamps flame signal is right, and steady, I would suspect the board, as well.
Cross contamination of the air supply is also a possibility.
Noel
603 335 6300 ex 5140
- 86.7K THE MAIN WALL
- 56 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
