Any use for old traps?
Steamhead (in transit)
Member Posts: 6,688
the Milvacos?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
old radiator traps
I have several old non-functioning radiator traps that I removed to replace them with modern ones that are servicable. However I hate to throw them away, they are so beautiful. They appear to be made of nickel, by H&M Engineering Co., Pittsburgh. Probably 100 years old since that is the age of our house. If anyone thinks these can be repaired and put to use, I will post them on Craigslist or such.0 -
I'll take 'em
e-mail me off-list and we'll set it up.
Outboard traps
Notice where the union nut is? Those traps went in "backwards" to the way modern traps are installed. The trap element sat outboard of the seat, and the steam.
They sure were a pain to get the cover back on without having the element cock sideways.
Ask me how I know.
Noel0 -
ok, how do you know?
I guess I did the right thing to replace with new ones!0 -
Yes, you did the correct thing for you.
Also, by giving them to a person who is the Guru in "Steam Systems", you have also added to the continued legacy of those that came before us.
Great credit to you in recoginizing that fact.
Bruhl0 -
After replacing 90 of them
in one building, it acted like none had been changed. About 5 of the new inserts had turned sideways as the cap was pushed against the spring and screwed in.
The question was, how many had turned and which ones were they (after discovering the first one)?
Noel0 -
indeed, they were
You have a memory like a steel trap!
Noel0 -
How could I ever forget
the Colby-Sawyer tour with the local King of Vapor?
Memory like a steel trap
...and that is one of many reasons he is my partner!
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
