adjustable air vents
kevin_60
Member Posts: 38
Thanks Brad i will give them a try.
What brand of adjustable air vents do you recommend.
The adjustable vent i have been using is a Vent Right air valve #1. I have had no trouble with these vents but fully
open is no bigger than a gordon #6. I would like an adjustable vent that would work like a gordon 4 to D.
Heat Timer Vari-Valves
have some pretty darn high capacities for what they look like. I personally like how they look too, especially on a TRV."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 167 Indoor-Air Quality
