adjustable air vents
kevin_60
kevin_60 Member Posts: 38
Thanks Brad i will give them a try.
  • kevin_60
    What brand of adjustable air vents do you recommend.
    The adjustable vent i have been using is a Vent Right air valve #1. I have had no trouble with these vents but fully
    open is no bigger than a gordon #6. I would like an adjustable vent that would work like a gordon 4 to D.
  • Brad White
    Brad White Member Posts: 2,399
    Heat Timer Vari-Valves
    have some pretty darn high capacities for what they look like. I personally like how they look too, especially on a TRV.
    -Ernie White, my Dad
