Master Venting
'Tis the season, so I say, make it a Menorah... especially if you do not have head-height. By extending the arms with more tees and vents you can fine-tune your venting to even the largest mains from a single reasonable tapping.
I think my ideal would be a centered #2 <i>shamish</i> with an equal number #1's off to each side... :)
I put in one recently that has four Gorton #1's (Same venting capacity as a "D" as noted elsewhere in this thread). I could have used a #2 and a #1 but could not fit the #2. The #2 I figure as worth about three to three and a half #1's by the way. OK call it four, no big deal...
DO buy the Gill and Pajek booklet. A good cause and fantastic resource, not found in stores!
