two-pipe steam pressure
I live in a six-story condo building with a two-pipe steam system. I have no technical training but am interested in the steam system, and the gauge on the boiler reads between 5 and 6 PSI when the boiler is operating.
Is this too high, and could it be adjusted downward without any adverse consequences? The only maintenance done on this system is at start-up and shut-down in the fall and spring. To my knowledge the building's radiators heat reliably.
I have no knowledge on whether or not the system is adequately vented.
