Proper Steam Boiler Firing Rate
between the time the burner starts and the time the boiler begins to send steam into the mains?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Steve Garson_2
    Steve Garson_2 Member Posts: 712
    Just had a Smith Model 19 6-section boiler cleaned and had the firing rate increased from 2.5gph to 3.5 gph. The boiler is rated 6gph, but it is 50% too big.
    I ran the system through a complete steam cycle to see how long it took for steam to heat all the radiators, although I did not wait for pressure to shut off, with the cost of oil:)
    Please tell me if these times sound reasonable for a cold start, i.e. 75* water. All times are from the start:
    Steam first starts: 13 minutes
    All mains hot: 20 minutes
    Rads start to show heat in first section: 23 minutes
    Rads 1/4 of sections hot: 28 minutes
    All rads 100% hot and can hear a few noticeably venting: 33 minutes
    Condensate pipe 30-feet from boiler gets hot: 48 minutes
    Does this sound about right?
    Steve
    Steve from Denver, CO
  • Steve Garson_2
    The steam starts leaving the boiler in 13 minutes.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    You might want
    to upgrade the main vents, especially if you can hear them venting. 7 minutes to fill the mains is a bit long, though you do say the radiators heat pretty much evenly. The rest of the time intervals should be OK.
  • Steve Garson_2
    The venting that I hear is on four radiators. The main vents get hot long before the radiators. The mains are vented per your advice a year ago.
