Are there Dumb questions?
Greg B
Member Posts: 3
I mentioned this in another post. Previous homeowner removed a cast iron radiator (baseray standup) and bridged the gap with a piece of pipe? Doesn't this degrade my system by connecting the inlet to the return and should I cut this out and just cap the ends instead? Sounds dumb I know but unless I ask....
It Depends...
on how it is piped.
I had a very small house once (four baseboard convectors) that was piped in a series, in one rad then out to the next etc.
If you stop the flow in one rad, you stopped them all.
I would think if it was piped in parallel then you could cap them off at the inlet and outlet.
JimThere was an error rendering this rich post.
Do you
have a monoflow (one pipe) system?There was an error rendering this rich post.
- 109 Chimneys & Flues
- 973 Plumbing
- 386 Solar
- 17 Recall Announcements
