tub shower units
Rodney Summers
Rodney Summers Member Posts: 748
I install ALOT of these and they are ALWAYS getting damaged. If you are the type of person that wants what they paid for, and the product MUST be in perfect condition, then I'd wait to get another one (I WAS once like this). I would not blame you one bit for wanting it in perfect condition, however, only you can weigh the pro's and the con's here as per time constraints. The repairs that can be made with these products are typically top notch (at least in my experience) and I would just get it repaired and move on. Life is too short.
One other thing I've learned about the repair of these, when it IS your fault. Go find yourself a good autobody guy that does corvettes (fiberglass repairmen) usually can do it better and cheaper, provided they have experience fixing them already.
Good Luck!
Robert O'Connor/NJ
  • m dewolfe
    m dewolfe Member Posts: 92
    damage to units in shipping
    I just had a new Aqua glass tubshower unit delivered to a jobsite onl to find a small hole knocked in the bottom of the tub. Custom order 4 week wait....ugh..supply house says "Hey fiberglass guys fix these suckers all the time no problem" And they say that many tubs are damaged in shipment. So custom fiberglass guy is coming out tommorow and says he will have it all fixed up in a couple of hours. What would you do? Send it back and wait a month or have it fixed on site?
  • Jim Bennett
    Jim Bennett Member Posts: 607
    fiberglass tubs
    We have had many cracks and and chips repaired with good result.
    Had a lovely pink one piece tub/shower with serious cracks after the tile guys stacked about a dozen 80 lb. boxes of tile in it. The repair guys matched the color perfectly.
    Had another done last year after a tenant emptied a fish tank in the tub, and let a couple of large rocks fall in also. Knocked a baseball size hole clean through the bottom. This one also was repaired good as new.
    Just my experiances
    Jim
  • Weezbo
    Weezbo Member Posts: 6,231
    summer time in the lower 48 is boomer this year..
    there is so many people needing to get things together,call the fiberglass tub repair dude ask him if he needs heat or if he takes care of it. the good guys going to show up knock it out tell you not to mess with it a day and away he goes. its done hes gone and you go on with your work.
    dont forget he is a professional so at least tell him its the best work like that you have seen a nd thank him. now after you have it all roughed in and the sheet rocker stomps a screw in the tub ,...the guy will come back figure you are providing him full time work :) and thank You :)
  • fiberglas shower
    After installing one piece fiberglas shower stall, there was factory defect hole at bottom ledge after cleaning. Guy came out and repaired and I couldn't even find the damaged area...
