Water use--Steam biler
Karl_8
Karl_8 Member Posts: 3
I have had serious problems with my boiler(s) over the years. I posted a thread here some time ago and indicated that my system had been using a lot of water and as a result, I'd replaced boilers over very short periods of time---averaging 10 years!!
I just got a new (another!!) new boiler installed and I replaced many of the vents in an attempt to make sure there is very little water loss. My system is set to automatically fill the boiler at certain points--the "filling" is set at 5 gallons. It appears that I may have used 3-4 gallons ovewr the course of the past two weeks. It hasn't been all that cold during this period---several days (nights) below freezing. First, is it too soon to determine if the new boiler is using excessive amounts of water? If not, is what I have used so far alot of water?
Karl
